ascii file with mixed Unix/Windows line returns
In my work I have to deal with ascii files which contain both Unix and Windows line returns (i.e. CR & CRLF).
I have noticed that these are correctly maintained when transferring to Unix from Windows but not when going back the way i.e. to Windows from Unix.
I have tried this with the latest version of WinSCP using both SFTP and SSH.
Is this a problem with my settings, the server or WinSCP?
Regards,
Danny Poulson.
Re: ascii file with mixed Unix/Windows line returns
And what's wrong with them? What version of SFTP are you using? What is your session configuration in respect to the end-of-line characters?
The same thing happens with SCP protocol
The same thing happens with SCP protocol, all the lines with a single LF character get the CR added for Windows, which in most cases is a good thing.
However if you need the file to be maintained exactly character for character for version control systems it is a pain.
Re: The same thing happens with SCP protocol
So you want to maintain the file binary the same? Then you need to turn force binary transfer mode.
