Only Certain/Specific File Types are Transferring
codeman
Hi, everyone. Has anyone come across an issue with transferring certain file types?
I'm using WinSCP 5.15.9, using SFTP binary transfer method. File types like .txt or .log transfer without problems right away when using a simple script file.
However, when it comes to transferring encrypted file types like .gpg, then it looks as if the transfer starts & immediately hangs.
This is what I'm using for a script:
open sftp://XXXXX@XXX.XXX.XXX.XXX/  -timeout=35 -rawsettings Compression=1 AddressFamily=1 SendBuf=0 SshSimple=0 SFTPMaxVersion=3 -hostkey="ssh-rsa 2048 XxXxX=" -privatekey="C:\Users\xxx\xxx\Testing\xxx.ppk" -passphrase="XxxX"
cd INBOX
put C:\Users\xxx\xxx\Testing\XXX.edi.gpg
Here's part of the log that gets generated:
@sessionlog@
. 2022-01-24 14:55:49.436 **Host is not communicating for 15 seconds.
. 2022-01-24 14:55:49.436 Wait for another 15 seconds?** ()
< 2022-01-24 14:55:49.436 Script: Host is not communicating for more than 15 seconds.
< 2022-01-24 14:55:49.436 Still waiting...
< 2022-01-24 14:55:49.436 Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
< 2022-01-24 14:55:49.436 Warning: Aborting this operation will close connection!
. 2022-01-24 14:55:52.285 Detected network event
. 2022-01-24 14:55:52.285 Data has arrived, closing query to user.
. 2022-01-24 14:55:52.285 Answer: OK
. 2022-01-24 14:55:52.285 Network error: Software caused connection abort
. 2022-01-24 14:55:52.285 Fatal error while disposing the SFTP queue.
. 2022-01-24 14:55:52.285 Transfer progress: Transferred: 32,736, Left: 0:00:00, CPS: 0/s
. 2022-01-24 14:55:52.285 Connection was lost, asking what to do.
If I use the WinSCP graphical user interface, then it seems to work without problems. I'd appreciate some input.
Are there specific parameters or switches I should be using/something I'm utterly missing? Thanks.
Re: Only Certain/Specific File Types are Transferring
Please post complete log both from GUI and script showing successful and failed transfer of the same file.
