Status code: 3, Message: 82694, Server: Access Denied, Language: US-ASCII
Renny
I am having an issue that I find a bit odd.
I am able to upload files to a remote SFTP via GUI and setting preserve time to disable.
Doing the same thing with .NET and it doesn't work.
$transferOptions.PreserveTimestamp = $false
$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off;
Snippet of my log:
 Script: put  -nopermissions -nopreservetime -transfer="binary" -resumesupport="off" -- "filename" "uplodfoldename"
. 2022-01-24 16:59:46.632 Binary transfer mode selected.
. 2022-01-24 16:59:46.632 Opening remote file.
> 2022-01-24 16:59:46.632 Type: SSH_FXP_OPEN, Size: 72, Number: 259
< 2022-01-24 16:59:46.764 Type: SSH_FXP_HANDLE, Size: 10, Number: 259
> 2022-01-24 16:59:46.764 Type: SSH_FXP_WRITE, Size: 32758, Number: 774
. 2022-01-24 16:59:47.630 Increasing send buffer from 262144 to 524288
< 2022-01-24 16:59:48.895 Status code: 3, Message: 82694, Server: Access Denied, Language: US-ASCII
. 2022-01-24 16:59:48.905 Received SSH2_MSG_CHANNEL_DATA for nonexistent channel 0
. 2022-01-24 16:59:48.905 Attempt to close connection due to fatal exception:
* 2022-01-24 16:59:48.905 Received SSH2_MSG_CHANNEL_DATA for nonexistent channel 0
