Installing WinSCP on AWS EC2
nodrik84@gmail.com
I was able to download and install program to EC2 instance through PowerShell.
I was able to set a connection between S3 bucket, uploaded files and etc.
I need to make a connection without using IAM credentials, is it possible?
S3 access role attached to Windows EC2.
I can run command to retrieve access and secret key through EC2 metadata, but WinSCP doesn't accept it.
Best, Nodir
Re: Installing WinSCP on AWS EC2
I'm sorry, but I'm not sure what does it mean "S3 access role attached to Windows EC2". Can you post some reference?
Nodrik777
In AWS cloud, you can run Virtual machine and give it access to S3 bucket storage. For that, you need to create IAM role with S3 access policy and after attaching it to Virtual machine.
Ok, but can you post some reference? I need to understand how does it work technically. Is it like IP-based authentication?
