Data integrity check when uploading with WinSCP to Amazon
thomass
Does WinSCP do a data integrity check when uploading files to Amazon S3?
Or is there a setting for this?
Thanks,
Thomas
Re: Data integrity check when uploading with WinSCP to Amazon
No integrity check is done. Do you think it's necessary? The connection is encrypted. So any incorrectly transmitted data would break the encryption, effectively failing the transfer.
