Filters
NinJak
Filters
I have been testing filters and I have figured out what I want, but the problem is that when I open filters and hit the drop-down arrow I see all of them I was testing and do not need them showing up. How do I delete the ones I do not need? I have tried to edit it. When I click on 1 and takes me too the window where I can choose files directors and other choices, but even if I remove them there they are still there on the drop down arrow.
Thanks Albert
NinJak
It's still there
So when I do that and close it and reopen filters they are still in the drop down list
is this a bug?
Thanks Albert
NinJak
Filters
Hello, I have decided to revisit this. I still do not understand how to delete the filters and them stay that way. What does summit me I please explain again.
Thanks Albert
Re: Filters
Open the Filter dialog. Drop down the list. Press Ctrl+Del. Submit the dialog with the OK button.
NinJak
filters
There must be a bug cause it does not work they are still there. Is there something else I can try?
Thanks Albert
Re: filters
Can you record a screencast documenting what you are doing? Or at least capture a set of screenshots.
NinJak
filters
So I open the filters and the little window opens up I click on the drop down arrow and choose the filters I have on that line. I leave it so the line is highlighted blue. I then hit Ctrl Del or Alt Del, I am not sure but it's what you said too use. The line goes away. Then I hit ok and the box closes. Then I close WinSCP just to be saved and reopen WinSCP. I have tried both closed and leaving open then I hit the Filter button and the box opens and I hit the drop down arrow and the filters that where highlight blue and went away when I hit del are still there I hope this makes more sense.
Thanks Albert
Re: filters
I do not understand what you mean by "choose the filters I have on that line". Anyway, it does not matter what line you select. The Ctrl+Del deletes all history. Not only the selected line.
By "I have tried both closed and leaving open", do you that even if you open the Filters dialog again right after submitting it with the "OK", the history is not cleared?
Post the screenshots please.
