First steps in scripting
Yves
i have tried my first steps in scripting but i was not successfull.
I used the sample script and changed it a little bit like this:
script.scp
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
# open user:password@example.com
# Connect
open myuser:mypassword@myhost
# Change remote directory
cd /folder
# Force binary mode transfer
option transfer binary
# Download file to the local directory c:\
get config.h c:\
# Disconnect
close
# Exit WinSCP
To execute it i used to following command:
c:\programme\winscp3\WinSCP3.com /console /script=script.scp
After this a window has opened and closed fast.
A manual connect by winscp is possible.
Whats my mistake? :?
Thanks for help!
Re: First steps in scripting
Run the script from already opened console window (type 'cmd' into start/run box) to keep the results once the script finishes.
Yves
thanks for your replay.
I get the error message
Cannot open file script.scp
The script is in the WinSCP folder.
Yves
ok, my fault.
Now I get the following:
C:\Programme\WinSCP3>
batch        on
confirm      off
EAccessViolation
Keine Sitzung
transfer     binary
Keine Sitzung
Keine Sitzung
Christoph
having similar problem
Hello all
Using Win2000 I'm facing the same issue: Using plain command "winscp3.exe /console /script=connect.txt" from command line is showing same result as Yves is reporting (while script-file is an adapted copy from the documentation-site). I went done to 3.7.6 as recommended but no change.
What I found interesting is the fact that the script command is not listed when typing help on the console (started with winscp3.exe /console). Does this ev. have any meaning or did I somehow miss an important part in the documentation? Thanks for your efforts
/Christoph, Berne-CH
Christoph
PostRe: having similar problem
Hi Martin
Well, one has to differntiate:
- "winscp3.exe /console /script=c:\programme\winscp3\connect.txt" is resulting in that very short popping window Yves already mentioned while
- "winscp3.com /console /script=c:\programme\winscp3\connect.txt" results in the error message "cannot open file c:\programme\winscp3\connect.txt"
Moreover: "winscp3.com xxx@host.tdl /console (xxx@host.tdl is the default session in the GUI) is properly opening the session ending with the command line on the console; the same with .exe instead of .com just with the difference an addition window is opened.
So, what about that error-message; do you have an idea?
Re: PostRe: having similar problem
I guess that it is pointless to ask you whether the file really exists and whether you have read access to the file :-)
Christoph
Martin,
I really have to appologize! The file does exist but it's named connect.txt.txt (some remaining typing from the old days with DOS; that's what's happening if project managers try to work outside their core competences ...).
Long story short: It's working fine now
Again sorry about that and thanks for following up on this anyway!
/Christoph
