No .dll file
jimbo311
USA
No .dll file
So I am working on scripting with WinSCP and it says you use this line to start
Add-Type -Path "WinSCPnet.dll"
but there is no .dll file within the WinSCP folder, I thought this would be included in the download?
Re: no .dll file
The WinSCP scripting uses no dll.
https://winscp.net/eng/docs/guide_automation
Your code is not for scripting, but for WinSCP .NET assembly. Though even the assembly is included in the installation. At least in recent versions of WinSCP. Maybe you have an old version.
Anyway, if you want to use WinSCP .NET assembly, you should download it separately.
https://winscp.net/eng/docs/library_install
