Need example of .NET Core 2.0 using FTP
nishit.2571988@gmail.com
Ahmedabad
I have tried with below code with FTP but not work got error like require authentication before user command. I have use WinSCP nuget package latest version in ASP.NET Core 2.0.
Can you please share me one example of ASP.NET Core 2.0 using FTP not SFTP.
var sessionOptions = new SessionOptions
    Protocol = Protocol.Ftp,
    HostName = "ftp.hostname.com",
    PortNumber = 21,
    UserName = "ABC@ftp.hostname.com",
    Password = "Test12"
try
    using (var session = new Session())
        session.Open(sessionOptions);
        var transferOptions = new TransferOptions
            TransferMode = TransferMode.Binary
        var transferResult = session.GetFiles("/test-destination/*.*",@"C:\test\",
            false, transferOptions);
        transferResult.Check();
        foreach (TransferEventArgs transfer in transferResult.Transfers)
            Console.WriteLine("Uploaded file: " + transfer.FileName);
catch (Exception ex)
    return false;
Re: Need example of .NET Core 2.0 using FTP
You have a code for .NET Core 2.0 using FTP. If it does no work, we need full session log file showing the problem (using the latest version of WinSCP).
Also, can you login anyhow? Like using WinSCP GUI? If you can, post its log file too. Or have the GUI generate working code for you:
https://winscp.net/eng/docs/ui_generateurl#code
