Can I limit bandwidth when running in /console mode
I do not see a switch in the documentation that will allow me to limit the upload speed as exists in the GUI. I would like to run a batch sync in the background at a slow enough speed so that it does not affect my online speed. In other words, as a cable modem user, I have a limited amount of upload capacity to the internet and winscp is so efficient that it can use it all and, therefore, I would like to limit it on my windows xp machine.
Site Admin -
- 43,223
- Prague, Czechia
Re: Can I limit bandwidth when running in /console mode
Added to TODO list.
- Guest
Added to TODO list.
Thank you.
- Guest
Has this been done yet?
Site Admin -
No.Has this been done yet?
- Guest
Has the feature been added yet?
Site Admin -
Yes. This request is tracked here.
- Guest
does is a far plugin support bandwidth limit?Yes. This request is tracked here.
Site Admin -
Yes, since 1.6.1.does is a far plugin support bandwidth limit?
Shiv
Speed - unlimited?
Hi, Can I use the 'unlimited' like in the GUI instead of a kibps? Meaning I would like the application to utilize the maximum bandwidth available.
Regards,
Shiv
Site Admin -
Re: Speed - unlimited?
Use empty value or 0. Though unlimited is the default. So you may not need to do anything.Hi, Can I use the 'unlimited' like in the GUI instead of a kibps? Meaning I would like the application to utilize the maximum bandwidth available.
- Guest
Thank you very much this helps!
