Double click attempts to open file like a directory
Version 5.19.4
If I change the "Resolve symbolic links" to CHECKED, then double-clicking the file transfers it. NOTE: the file is not a symbolic link: it is a
I believe this is a bug.
- Options >> Preferences >> Panels >> Double-click is set to "Copy"
- Session >> Sites >> Site Manager ... >> (select a site in the left pane)
>> Edit >> Advanced ... >> Environment/Directories >> Resolve symbolic links is NOT CHECKED
>> Edit >> Advanced ... >> Environment/Directories >> Follow symbolic links to directories is CHECKED
image.
image.
