Problem similar to https://winscp.net/forum/viewtopic.php?t=27529
Re: Problem similar to https://winscp.net/forum/viewtopic.php?t=27529
melvinpmathew@gmail.com
Info
On more investigation found that command line WinSCP is causing the issue - triggers from the WinSCP C# api called winscp.exe. This happens also via regular command line on windows.
Attached the logs from that.
This is the command line command used :
winscp.com /log="C:\temp\WinSCP.log" /command "open sftp://user:pass@10.27.119.193/" "put C:\\temp\\Baylor_Miraca_Genetics_Laboratories_LLC_45D0660090_TEST.csv /home/bgdevtest/Texas/" "exit"
Though - using WinSCP GUI works fine!
I am missing something.
  • WinSCPSession_20211028.log (149.42 KB, Private file)
Description: Logs
Description: Log from Winscp api
Description: Log from command prompt on windows
Successfull log via GUI
Yes, that correct. Able to submit files via GUI. Attached logs. But using the C# WinSCP API, fails almost all the time with a "Network error."
  • winscp.log (12.81 KB, Private file)
Description: Successfull transfer - WINSCP GUI
These are the logs from the api - during the same time frame, its throwing errors and not completing the upload.
  • WinSCPSession_20211116.log (35.04 KB, Private file)
  • WinSCPDebug_2021111608371347111.log (67.8 KB, Private file)
Re: Successfull log via GUI
Full log file please.
Need one answer: Is it possible to generate a config file from WinSCP GUI? I can maybe use that for the API and check.
https://winscp.net/eng/docs/ui_generateurl#code
