dont download file with progresbar
AndrewVas
Russian
I used this WinSCP library in WPF to download files from the FTP server. Everything worked until I decided to add an installation with a progress bar:
void SessionFileTransferProgress(Object sender , FileTransferProgressEventArgs e)
    MessageBox.Show(e.FileName);
It was giving an install error!
Without this, everything works, but I still need to add the progres bar update.
The size of the files folder is very huge!
My code:
    // Will continuously report progress of transfer
   // session.FileTransferProgress += SessionFileTransferProgress;
    // Connect
    session.Open(sessionOptions);
    try
        // Download files and throw on any error
        session.GetFiles(url, path);
    finally
        // Terminate line after the last file (if any)
        MessageBox.Show("Download stop");
Version WinSCP: 5.19.3
Re: dont download file with progresbar
What "install error"? What exact error are you getting? Post full exception stacktrace.
