VBA and closed Port
OKL
Germany
VBA and closed Port
I have created an Microsoft Access Application with integrated WinSCP to download and upload Files to our FTP Server.
Everything works fine, but if the port for FTPS is closed, the WinSCP is waiting for 120 seconds. The switch .TimeoutInMilliseconds = 5000 does nothing in this case. If there is no connection to the internet or the host is not available, it fails instantly and the dialog to update closes.
Public Function SafeCopy(mysession As Session, ziel As String, quelle As String, direction As Integer, delfile As Boolean) As Boolean
On Error GoTo 2
Dim ergebnis As String
SafeCopy = False
    Dim mysessionoptions As New SessionOptions
    With mysessionoptions
        .protocol = protocol.protocol_ftp
        .Hostname = Hostname
        .UserName = ftp_User
        .Password = ftp_Password
        .ftpsecure = ftpsecure.FtpSecure_Explicit
        '.DisableVersionCheck
    End With
    ' Connect
    mysession.Open mysessionoptions
    ' Upload files
    Dim myTransferOptions As New TransferOptions
  ' Const transfermode As String = "TransferMode_Binary"
    myTransferOptions.transfermode = TransferMode_Binary
    'myTransferOptions.Remove = True
What can I do to check if the port is open or cancel it faster?
Thank you.
Re: VBA and closed Port
