Support for Azure Data Lake (ADLS V2)
rajeevsriv
Is there any documentation on using Azure Data Lake (ADLS V2)? I am trying to move files from an SFTP site into ADLS where SFTP is not enabled.
Thanks!
Re: Support for Azure Data Lake (ADLS V2)
I do not have any experience with ADLS. What protocol does Azure Data Lake use? Does it have only some proprietary API? WinSCP supports SFTP, FTP, S3 and WebDAV protocols. If none of these can be used with ADLS, then you cannot use WinSCP.
