Check if files are uploaded successfuly
Abeluko
Hi, by first, sorry for my english...
I try to make a PowerShell script to upload files to remote SFTP Host, but I need to make a CSV with results, and use $TransferEventArgs.IsSuccess to know if these file is uploaded correctly, but always return True. If work True, if fail, True too...
What need to use to know if the files are uploaded successfully?
Thanks for all!!
Re: Check if files are uploaded successfuly
Please show us your code and attach a session log file showing the failed upload that resulted in TransferEventArgs.IsSuccess = True.
Abeluko
Barcelona
Hi Martin.
Where I can see de log
this is my code:
try
    # Carga del ensamblado .NET para WinSCP
    Add-Type -Path "C:\tmp\smeg\winscp\WinSCPnet.dll"
         # Configuración de opciones de sesión
        HostName = "127.0.0.1"
        PortNumber = 22
        UserName = "user1"
        Password = "user1"
        SshHostKeyFingerprint = "ssh-rsa"
    # Configuración de caminos local y remoto
    $remotePath = "/"
    $LocalPath = "d:\XPO\data\*.csv"
    $BackUPPath = "d:\XPO\sent\"
    $LogFile = "d:\XPO\log\GPoutput.csv"
     # Configuración de opciones Conexión
    $sessionOptions.AddRawSettings("FSProtocol", "2")
    try
        # Conexión
        # Opciones de configuración de transferencia
        $session.add_QueryReceived( {
            #Write-Host "Error: $($_.Message)"
            $_.Continue()
        $transferOptions = New-Object WinSCP.TransferOptions -Property @{
            PreserveTimestamp = $False
        #$transferOptions.AddRawSettings("IgnorePermErrors", "1")
        $transferOptions.AddRawSettings("ExcludeHiddenFiles", "1")
        $Item = $Null
        # Envio de archivos hacia el host remoto
        foreach( $Item in Get-ChildItem $LocalPath )
            $NewName = "SMEG_Alvaranes " + (Get-Date -Format "yyyy-MM-dd HHmmss") + ".csv"
            rename-item $Item -NewName $NewName
            Start-Sleep -Seconds 1
            $TransferResult =
                $session.PutFiles( $Item, $remotePath, $false, $transferOptions)#.Check()
            # Throw on any error
            $transferResult.Check()
            write-host $transferResult.IsSuccess
            #Crear Carpeta de Backup
            $st1 = $BackUPPath
            $st2 = Get-Date -Format "yyyy"
            $st3 = "\"
            $st4 = Get-Date -Format "MM"
            $Backup = [System.String]::Concat($st1, $st2, $st3, $st4)
            $ExBk= Test-Path $Backup
            if ($ExBk -ne $True)
                mkdir $Backup
            #Comprobar si se ha realizado la copia correctamente
            if (!$transferResult.IsSuccess )
                Write-Host $Item.name + $transferResult.IsSuccess + "Error"
            else
                Write-Host $Item.name + $transferResult.IsSuccess + "Success"
                Move-Item $Item $Backup
            #Output the array to the CSV File
            $Output =New-Object -TypeName PSObject -Property @{
                File = $Item.name
                Date = Get-Date -Format "yyyy/MM/dd"
                Hour = Get-Date -Format "HH:mm:ss"
                Result = $transferResult.IsSuccess
                Host = $sessionOptions.HostName
                Path = $remotePath
                UserName = $sessionOptions.UserName
            } | Select-Object Date,Hour,File,Result,Host,Username, Path,Error
            $Output | Export-Csv $LogFile -NoTypeInformation -Append
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
   #Muestra Errores
   if ($Null -ne $($_.Exception.Message)) {
       #Registra Errores en el Log
            Error = $($_.Exception.Message)
        } | Select-Object Date,Hour,File,Result,Error
    exit 1
To generate the session log file, set Session.SessionLogPath.
Though are you aware that none of your code that queries IsSuccess is ever reached with IsSuccess = False, as the previous .Check call would throw an exception?
