SFTP PutFile using a stream does not set file permissions
I am trying to use the .NET Assembly using the following code:
session.PutFile(inputStream,remoteFile,options: new TransferOptions { FilePermissions = new FilePermissions { Octal = "666" }});
The file transfers successfully but the permissions do not update. Using the PutFiles command with a local file works correctly.
Any ideas?
Re: SFTP PutFile using a stream does not set file permissions
Indeed, preserving permissions is not supported with Session.PutFile.
That is unfortunate. That does mean that for most use cases this command is useless.
Come on, most use cases use the default permissions.
