Direkt scp to destination directory
Coyote
is it possible to copy directly from a unix server to a windows directory without using a temp-dir in which the file is temporarily stored and copied again? (It wastes a lot of space and time...)
Coyote
Yes it should. It does not for you?
Note: Files are deleted few minutes after transfer is finished. This is because I cannot detect when Windows finishes coping files from temp directory to destination directory. If you close WinSCP too early, files remain in temp folder. Otherwise thay should be deleted.
