The value supplied is not valid, or the property is read-only. Change the value, and then try again
dkimmo
Australia
Hi, I'm getting the error mentioned above in a script I'm trying to set up for automated-deployment to a web server. I'm new to both PowerShell scripting and WinSCP so forgive me if this is a common problem, but I did try searching the forum first for similar topics.
Here's the current script I'm trying:
param(
[string]$environment
$confirmed = Read-host "Put the site into maintenance mode? (y/n)"
if ($confirmed -eq "y") {
    try {
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = [System.Net.Dns]::GetHostName()
        UserName = "root"
        Password = "password"
        PortNumber = 2222
        SshHostKeyFingerprint = "ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBPTEv+TGGfNqJeP0uV5E/cYHy3TEtNAT7DJpJcLj7WbHCBtCWAIvtQ2dO8s+vQrNcK5G+W1VrncvitR3RFvB3ag="
    try
        # Connect
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
} elseif ($confirmed -eq "n") {
    return
else {
    Write-Host("Invalid input. Please enter y/n.")
Edit: Also, what editor should I be using for PowerShell scripting? Currently trying to use PowerShell ISE but not sure if there's one that will make it easier...
Re: The value supplied is not valid, or the property is read-only. Change the value, and then try again
What you pass to SessionOptions.SshHostKeyFingerprint seems like a full host key. While the property accepts a hostkey fingerprint.
See https://winscp.net/eng/docs/faq_hostkey#automation
For general information also see SSH host key/TLS host certificate fingerprint “…” does not match pattern “…”.
