- Guest
Support for Windows 2003 x64
When I start WinSCP on Windows 2003 x64 an error message appears "Ungültiger Zugriff auf den Speicher". Seems that there is a problem with the memory management. Is there a know bug?
Site Admin -
- 43,049
- Prague, Czechia
Re: Support for Windows 2003 x64
What executable do you run? Standalone or the one contained in installation package?
swrona
3.8.2 on XP x64
Ive just setup my new x64 XP system, and of course, I had to install WinSCP. Any chance that there will be a x64 native version in the works?
Site Admin -
Re: 3.8.2 on XP x64
What's the advantage? :-)Ive just setup my new x64 XP system, and of course, I had to install WinSCP. Any chance that there will be a x64 native version in the works?
- Guest
Re: 3.8.2 on XP x64
The ability to drag and drop to the desktop aparently. This hasn't been working since I have installed on my x64 system. Maybe coincidence, probably not.What's the advantage? (to an x64 version of WinSCP):-)
Site Admin -
Re: 3.8.2 on XP x64
Do you have drag&drop shell extension installed or not?The ability to drag and drop to the desktop aparently. This hasn't been working since I have installed on my x64 system. Maybe coincidence, probably not.
Sprudeldudel
I have a similar Problem. x64 running and cannot connect to the apache webserver at my university.
Site Admin -
- 43,049
- Prague, Czechia
I do not see any similarity. Also you cannot connect to webserver with WinSCP. You may be able to connect to an SSH server running on the same machine as a webserver. What the error message?I have a similar Problem. x64 running and cannot connect to the apache webserver at my university.
- bcrooker
- 1
- Virginia, USA
Re: 3.8.2 on XP x64
I am also running Windows XP x64 and the drag and drop does not seem to work. I have tried disabling it and re-enabling it from the preferences and then rebooting without help.
HielkeHoeve
Drag and drop doesn't always work plus winscp sometimes crashes for no aparent reason. Is there a debug version so I can let VS 2008 show me what's going wrong?
The advantage is that you don't have to run it in an emulated environment, which makes me shiffer a little. It'll go a bit faster, which is always nice. Most processors (Intel core 2 duo, AMD Athlon etc) are already 64 bits, most people just don't know it...
Site Admin -
- 43,049
- Prague, Czechia
When it does not work?Drag and drop doesn't always work
In some specific situation? Or randomly?plus winscp sometimes crashes for no aparent reason.
WinSCP is not compiled in VS.Is there a debug version so I can let VS 2008 show me what's going wrong?
- Guest
Drag and drop only works if you are using the 32 bit explorer (by default windows uses the 64 bit explorer)
Site Admin -
What does not work exactly? What drag&drop mode in WinSCP have you selected? What version of WinSCP are you using?Drag and drop only works if you are using the 32 bit explorer (by default windows uses the 64 bit explorer)
HielkeHoeve
Haven't been able to reproduce the problem with 4.0.5, must have been a user error :)
I should have been more clear about this, it's the same error as reported here:
https://winscp.net/forum/viewtopic.php?t=5584
- HielkeHoeve
- 1
- Netherlands, Enschede
Btw, any idea if C++ Builder 2007 can also compile WinSCP?
edit:
CodeGear C++ Builder 2007 can convert it to the newer version, but compiling it is a different thing. Its whining about the libs of version 6 :roll:
edit:
Site Admin -
I haven't tried that, but I doubt.Btw, any idea if C++ Builder 2007 can also compile WinSCP?
