"could not find the string" dialog box always sends WinSCP window to the back
yawnmoth
Texas
If I'm using WinSCP's built in text editor and then do Ctrl+F to find a string and it doesn't find the string it's like the WinSCP window gets put behind every other open window.
So like let's say I was using my Google Chrome full screen and then, via the Windows taskbar, I go to WinSCP / it's text editor and do Ctrl+F to find a string that doesn't exist. At that point the Google Chrome window will suddenly pop to the front whereas WinSCP will go to the back. Like if I shrink every window from the taskbar I have to shrink all open windows to see WinSCP again.
This is super annoying behavior. Seems to me like it's a bug. Can it be fixed?
Re: "could not find the string" dialog box always sends WinSCP window to the back
Thanks for your report. Though, I cannot reproduce this. What version of Windows? What version of WinSCP? Anything unusual about your Windows configuration? Some Desktop/Shell extension? How many monitors? Which one is the primary one? What exactly is "Google Chrome full screen"? The F11 mode?
