Possible multiple Authentications?
KiloSierra
Germany
Is it possible to use two Authentications?
The Problem is that we need to Authenticate us first at the firewall and then to SFTP Server.
The Command works fine.
"open sftp://xxxx:yyyy@10.10.10.10/ -hostkey=""ssh-dss 1024 yxyx""" ^
This is only the Connection to the SFTP server but before we can connect to the SFTP Server we need to Authenticate us at the firewall.
Re: Possible multiple Authentications?
Sorry, but that's vague.
How the authentication to the firewall works? Is it like a proxy? Or an SSH jump server? Or something else?
Can you connect to the server through the firewall in WinSCP GUI? Or in any other SFTP client? How do you do it?
