Help uploading htmls
dmay
I've successfully logged into wnscp and created a webpage using word. When I drag and drop the html file on to the /local/home/dmay, disconnect and go to the webpage...i get nothing but a link to our parent directory. What do I need to do to get this working
Re: Help uploading htmls
  • Make sure that you have set file permission correctly (usually "Others" has to have read permission).
  • Make sure, that you've uploaded file to directory that is "visible" from web. Is is usually directory like "public_html" in your home.
