Azure App Service - connection attempt failed
lnl@energidanmark.dk
Denmark
The Solution in short:
App Service running .NET App
Always on is set to On.
The app is downloading file and fileinfo from FTP server using WinSCP in the C# code.
From Log file:
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
It seems to fail at the code part:
var sessionOptions = new SessionOptions()
    Protocol = Protocol.Ftp,
    HostName = _hostName,
    UserName = _userName,
    Password = _password,
    TimeoutInMilliseconds = 60000,
_session = new Session();
_session.DisableVersionCheck = true;
_session.DebugLogLevel = 0;
_session.ExecutablePath =
    Path.Combine(AppDomain.CurrentDomain.BaseDirectory + "winscp.exe");
_session.Open(sessionOptions)
The error only occurs when vi run the App on Azure, I cannot recreate the error in Debug on my local machine. If I debug the App local, it seems to get the production App on Azure to start running.
I do not know if I have to change the WinSCP settings in the code, or I should change the settings in Azure App Service.
Re: Azure App Service - connection attempt failed
If the code works in other environments, I'm quite sure that no change in the code will help to make it working on Azure. This looks like a firewall issue.
