Upload not possible with TLS 1.3
Jan1205
FTP upload: With TLS 1.3 the attached file could not be uploaded. With TLS 1.2 the upload successfully finished.
Please rename style_alt.css.txt in style_alt.css.
Version: WinSCP 5.19.1
Re: Upload not possible with TLS 1.3
Please attach a full session log file both for TLS 1.2 and TLS 1.3. Also, do you mean that you can upload other files with TLS 1.3? Can you post a log for that too?
Sorry for the late answer. FTP upload is possible for TLS 1.2 and TLS 1.3. With TLS 1.3 only the attached file could not be uploaded. With other files works TLS 1.3 perfectly.
I added two logfiles for the file style_alt.css: TLS 1.2 and TLS 1.3 (fail)
You also find a log for a upload with TLS 1.3 which successfully finished.
Thank you for your support.
Description: TLS 1.3 test.txt (sucessful)
Description: TLS 1.3 style_alt.css (fail)
Description: TLS 1.2 style_alt.css (sucessful)
Thanks. I'll take a look. Can you upload the file using any other FTPS client?
Re: Upload possible
Can you post verbose logs from the other client? Can I have a test account on your server?
