Can't navigate to directory after deleted and re-created
jhob
UK
WinSCP v5.19.1
Win 10 Pro build 19043
In a project I have a dist directory that I FTP to the server with WinSCP. When the project is built the dist directory is deleted and recreated with the build files.
If this directory is currently selected in WinSCP then it does not reappear in the file browser when recreated and cannot be navigated into when clicked on in the navigation pane.
I recorded a screencast to demonstrate the issue.
Description: Screencast
Re: Can't navigate to directory after deleted and re-created
jhob
UK
Thanks Martin,
I tried replicating the issue with the debug version but it worked perfectly. The 'dist' directory reappeared in the navigation panel correctly and could be clicked on again in the files panel.
I tried the same operation again with my installed version and the bug persisted.
I've attached the log file anyway.
jhob
UK
After this error occurred I opened a new session on a different site and on trying to download over FTP to a different directory, which had opened fine in the browser, I got the following error:
WinSCP was not able to detect folder, where the dragged file(s) was dropped
On restarting the application this download worked fine. It seems related to me.
