WinSCP.exe fails to run on Windows version 20H2
CyberRanger
I recently upgraded my Windows version from 1809 to 20H2. Since then, I'm unable to use WinSCP. If I uninstall the program, reboot, then reinstall it (WinSCP-5.19.1-Setup.exe), I can use it once. But if I close it and try to reopen it, the WinSCP window does not launch.
Windows Event viewer under Windows Log -> Application has the below error message:
Faulting application name: WinSCP.exe, version: 5.19.1.11552, time stamp: 0x00000000
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0096034f
Faulting process id: 0x17d8
Faulting application start time: 0x01d773673c44162f
Faulting application path: C:\Program Files (x86)\WinSCP\WinSCP.exe
Faulting module path: unknown
Report Id: e70be6b7-ba9a-4eb7-bd7d-c49a3b87862c
Faulting package full name:
Faulting package-relative application ID:
Re: WinSCP.exe fails to run on Windows version 20H2
