Non-existing remote folders getting synchronized
JanB1
So, I updated to 5.19.1 (Build 11552) today on my Win 10 machine and I'm connecting to a remote FTP that worked for me before.
Now I see a folder "/<previous level>" and "/<path from root" on the remote.
The <previous level> always shows the previous folder, for example if I have
'/root/sites/contact' and I'm in 'contact' it will show "/root/sites".
The <path from root> at the same time will show the path to the current folder, for the example above "/rot/sites/contact"
Problem is that the program tries to synchronize these virtual remote folders and throws errors and creates these folders on my local folder.
  • WinSCP_1kU1dilFJN.png (22.61 KB, Private file)
Re: Non-existing remote folders getting synchronized
What version were you using before?
JanB1
Previous version was 5.17.10
As requested. I replaced all private parts with [redacted], I hope I got them all.
  • WinSCP.log (16.32 KB, Private file)
Description: Verbose Debug 2
Imo, it's a bug in the server. But ok, since the previous versions of WinSCP were compatible, I've restored the compatibility:
https://winscp.net/tracker/2004
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
