.bat/script File Error on Windows Server 2019
caprarioa
Los Angeles
I have a windows Server 2019 with winscp installed. I have a sftp server I am trying to send a static file to from an internal folder. I have a script (.txt) file and a .bat file. I have searched many forums and no matter what I try I think my knowledge is too limited to correct my errors!
.bat file:
cd C:\Program Files (x86)\WinSCP winSCP.com /script=C:\Program Files (x86)\WinSCP\autoupload_script.txt
Script file:
open sftp://username:password@address.com/
cd E:\folder1\folder2\folder3
put E:\folder1\folder2\folder3\filetobetransfered1.csv
Re: .bat/script File Error on Windows Server 2019
It should be two lines. and you also need to quote the paths with spaces:
cd "C:\Program Files (x86)\WinSCP"
winSCP.com /script="C:\Program Files (x86)\WinSCP\autoupload_script.txt"
