Connection is always refused by Ubuntu in a Virtual Machine (Hyper-V)
manda3d
Hi, I'm new, I watched so many YouTube Tutorials but they just enter the IP address without explaining how did they get it.
Host name:
I tried to intentionally fake the IP address, for example 172.25.160.66 instead of 172.25.160.65 then the result is "Network error: Connection time out" instead of refused, which means that the IP address exists but just refused.
Username and password:
People say that the default username and password of Ubuntu are nothing, so I just type nothing for them.
WinSCP: Version 5.19.1 (Build 11552)
To zoom the image below, right click and image in new tab.
manda3d
Step 1 - Enable connection
Connection to FTP Always Refused
# Backup the current configuration file. (optional)
sudo mv /etc/vsftpd.conf /etc/vsftpd.backup
# Uninstall vsftpd and purge the configuration files.
sudo apt-get remove --purge vsftpd
# Lastly, re-install vsftpd.
sudo apt-get install vsftpd
# Test
ftp -p x.x.x.x
The default password for the user 'ubuntu' on Ubuntu is blank.
Step 2 - Permission to edit the file /etc/vsftpd.conf
"You are not the owner..." message when trying to access folder
sudo chown -R username /path/to/directory
Example:
sudo chown -R ubuntu /etc/vsftpd.conf
Step 3 - Enable writing
Permission denied in FTP even though I'm the owner
In the file "/etc/vsftpd.conf", uncomment the line
#write_enable=YES
Important:
Watch this video how to change the file permission in Terminal instead of using a Text Editor:
https://www.youtube.com/watch?v=qpt5mxVVJoE
sudo su
vi /etc/vsftpd.conf
ESCAPE :wq (to exit)
Save the file and restart vsftpd with sudo service vsftpd restart
Shokoofeh
Re:Connection is always refused by Ubuntu in a Virtual Machine (Hyper-V)
first run this command in Linux
sudo apt-get install openssh-server
then on WinSCP use SFTP instead of FTP and set the port to 22.
