Winscp 5.13.8 Portable : System.IO.Error.WinIOError: Could not find file filename.xml
snowfrost80
Hi All,
I am using Winscp 5.13.8 Portable and on and off I am encountering this error" System.IO.Error.WinIOError: Could not find file filename.xml" . I have checked that the xml file is generated and it caused my job to die. Can I check whether does this issue only happened to this version ? I have read that the xml will be auto generated no matter what.
Appreciate anyone who can help.
Re: Winscp 5.13.8 Portable : System.IO.Error.WinIOError: Could not find file filename.xml
Under what circumstances do you get the error? Please attach a full session log file showing the problem (using the latest version of WinSCP).
