diegomath
Windows 11 - Files in files list not right selected
Files are selected wrongly, causing problems with dragging, seems to only occur on Windows 11
Site Admin -
- 43,055
- Prague, Czechia
Re: Windows 11 - Files in files list not right selected
Can you please elaborate on "wrongly" and "causing problems"?
Site Admin -
I was not able to identify any problems with selecting files on Windows 11.
Dante69
Selecting items windows 11
I have had the same behaviour - its like the old trolling cursor that would click one item above where it should etc and become enough of a pain to notice and enough of a pain to comment....
Site Admin -
Re: Selecting items windows 11
I do not think it's a good idea to try to workaround some glitch in pre-release version of Windows.
So would you please report this to Microsoft instead?
Nubzior
I can confirm there is problem with cursor position on what you click on the list tree.
Windows 11 21H2 22000.71
Site Admin -
@Nubzior: Would you please report this to Microsoft?
Nubzior
Wht? Others programs double commander total commander works without problem
Site Admin -
- 43,055
- Prague, Czechia
@Nubzior: There was no change on WinSCP side. There was change on Microsoft side. So why do you think it's a problem of WinSCP? It seems that Microsoft broke something.
Also afaik, Total Commander does not use standard Windows list control, but a custom one. While WinSCP does use the standard Windows list control. So Total Commander is not relevant to the problem.
And it's quite likely that Microsoft didn't break the list control completely. They would have noticed for sure, if they did. They broke some specific set up that affects limited set of applications only.
Please report it to Microsoft.
RickyShade
Donor - Joined:
- 2
Yeah, I think this has been fixed in the latest build as it hasn't happened yet. Though it did take a while of using WinSCP before I noticed it last time, but so far so good.
Site Admin -
@RickyShade: Thanks for your feedback.
