Transfer options - don't remember the entered exclusions of directories
pablo
Poland
With the option "Automatically update remote directory" -> "transfer options" it don't remember the entered exclusions of two directories.
Re: Transfer options - don't remember the entered exclusions of directories
I'm not sure I follow.
Did you expect that with enabled Automatically update remote directory, WinSCP should always remember your transfer settings? Why?
Or did you mean something else? What are you trying to achieve?
pablo
It only remembers 3 items from the "Exclude Directories" option, and no more.
It's supposed to remember because I'm marking it to use the same settings next time.
Where are you "marking it to use the same settings next time"?
Please provide us step-by-step instructions for reproducing the problem.
More screenshots might also help.
pablo
Poland
#3 - I add two new directories, click Start, then Stop, close the window, open it again and the two directories added earlier are no longer on the list (#5) :/
Are you sure it remembers those three directories? Aren't those three directories actually a part of your default transfer settings?
pablo
I don't know...
How to check it?
What does it do? It remembers three directories but not the others. How to make it remember as many as I enter?
