WinSCP Compatibility with Windows server 2019
Rasim
India
Hi Team,
We are currently using WinSCP version 5.1.1 on Windows Server 2012 machine.
We are planning to upgrade the server OS to Windows Server 2019.
Can you please help verify the compatibility of existing app with Windows Server 2019.
If its not compatible, kindly suggest the version which is compatible.
Re: WinSCP Compatibility with Windows server 2019
WinSCP 5.1.1 is 9 years old. You absolutely should not use it.
Please use the latest version of WinSCP.
