5.19 cannot access an empty drive
Aquamarine
The Ver.5.19 cannot access an empty drive and reports an error:
System Error. Code: 2.
系统找不到指定的文件。
BTW: How can I download an older version of the language file?
Re: 5.19 cannot access an empty drive
Local drive or remote drive? What kind of drive is it? Do you mean that is was working is older versions of WinSCP? What version?
Why do you want to download older version of translation file? They are part of the installation package. If you want to downgrade, just download the old installer. Anyway, you can just edit the version number in the translation file download URL.
I tested it on a local ramdisk. All major versions prior to 5.17 were working. I'm an old user of WinSCP.
Thank you, I have downloaded the translation file of Ver.5.17.10.
