WinSCP extensions using batch language are stored with UTF-8 BOM
alerosmile
WinSCP extensions stored in %APPDATA%\WinSCP\Extensions are encoded with UTF-8 including a BOM even if the original extension is encoded with ASCII. This is a problem if the extension is written as a batch file. cmd does not support files with BOM. Is there a workaround for this?
Re: WinSCP extensions using batch language are stored with UTF-8 BOM
I have added this issue to the tracker:
https://winscp.net/tracker/1993
