PowerShell - Connection closed by warning Banner
filipe
London
Hi Guys,
Trying to setup the PowerShell script to automate file transfer but I believe a banner is causing the server to close the connection as I can authenticate fine using GUI.
Is there a way that I can bypass the banner when using PowerShell script?
Re: PowerShell - Connection closed by warning Banner
Please attach a full session log file showing the problem (using the latest version of WinSCP) as well as a log file from the GUI.
