WinSCP (current stable) does not show symlinks
jmar83
I created it on httpdocs folder on SSH console. WinSCP does not show. But when I upload a file with WinSCP and then make ls in that httpdocs dir, then I will see both.
How to make WinSCP show symlinks?
Thx for feedbacks!!
Re: WinSCP (current stable) does not show symlinks
jmar83
Hi Martin
Thank you very much for your feedback. Firstly, i was thinking that it is an option similar to the "Show hidden files" (e.g. ´.htaccess´) - but, at least so it seems, it is not.
Logs (and also screenshots) are attached and flagged as "private" - so just for you...
_________________
With best regards
jmar83
  • WinSCP Logs - symlink problem.zip (115.45 KB, Private file)
Description: logs & screenshots
The log shows only .well-known file in the folder. Which I do not see in your terminal screenshot. Can you explain? On the other hand, can you see the symlink using any other FTP client? Try setting "Use MLSD command for directory listing" to Off.
jmar83
At least, i see the symlink in the SSH console - in fact, it exists. Now i will look with that MLSD thing...
_________________
With best regards
jmar83
jmar83
Yes, when i set that MLSD thing to "off", i see it. (With a symlink icon, with arrow...)
Question: Is that a feature or a bug...? ;-)
_________________
With best regards
jmar83
