Can not connect and receive "Incoming packet was garbled on decryption" msg.
belamy2
I've tried to use WinSCP2 ver. 2.2.3 to connect to remote host. My problem is I can not connect to remote server and receive message: "Incoming packet was garbled on decryption".
When I use scp command from Linux system to connect to that remote host all files are copied correctly.
Below is debug log from my scp Linux connection:
OpenSSH_3.1p1, SSH protocols 1.5/2.0, OpenSSL 0x0090602f
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug1: Rhosts Authentication disabled, originating port will not be trusted.
debug1: restore_uid
debug1: ssh_connect: getuid 500 geteuid 0 anon 1
debug1: Connecting to egb.pl [xxx.xxx.xxx.xx] port 22.
debug1: temporarily_use_uid: 500/501 (e=0)
debug1: restore_uid
debug1: restore_uid
debug1: Connection established.
debug1: read PEM private key done: type DSA
debug1: read PEM private key done: type RSA
debug1: identity file /home/user/.ssh/identity type -1
debug1: identity file /home/user/.ssh/id_rsa type -1
debug1: identity file /home/user/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version 2.0.13 (non-commercial)
debug1: match: 2.0.13 (non-commercial) pat 2.0.13*,2.0.14*,2.0.15*,2.0.16*,2.0.17*,2.0.18*,2.0.19*
Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.1p1
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client 3des-cbc hmac-md5 none
debug1: kex: client->server 3des-cbc hmac-md5 none
debug1: dh_gen_key: priv key bits set: 184/384
debug1: bits set: 542/1024
debug1: sending SSH2_MSG_KEXDH_INIT
debug1: expecting SSH2_MSG_KEXDH_REPLY
debug1: Host 'egb.pl' is known and matches the DSA host key.
debug1: Found key in /home/user/.ssh/known_hosts:1
debug1: bits set: 511/1024
debug1: ssh_dss_verify: signature correct
debug1: kex_derive_keys
debug1: newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: waiting for SSH2_MSG_NEWKEYS
debug1: newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: done: ssh_kex2.
debug1: send SSH2_MSG_SERVICE_REQUEST
debug1: buggy server: service_accept w/o service
debug1: got SSH2_MSG_SERVICE_ACCEPT
debug1: authentications that can continue: publickey,password
debug1: next auth method to try is publickey
debug1: try privkey: /home/user/.ssh/identity
debug1: try privkey: /home/user/.ssh/id_rsa
debug1: try privkey: /home/user/.ssh/id_dsa
debug1: next auth method to try is password
user@remote.host.com's password:
and after entering password files are copied.
Grand Apeiron
RE: Can not connect and receive "Incoming packet was garbled on decryption" msg.
Hi all,
i just expected the same problem when connecting
to a sshd2 on a debian woody machine.
If I use sftp2 on that debian machine to connect to itself everything works fine.
If i try psftp i get the following error:
Fatal: unable to initialise SFTP: could not connect
Verbose output is:
Looking up host "10.1.4.1"
Connecting to 10.1.4.1 port 22
Server version: SSH-1.99-2.0.13 (non-commercial)
We believe remote version has SSH2 HMAC bug
We believe remote version has SSH2 key-derivation bug
We claim version: SSH-2.0-PuTTY-Release-0.53b
Using SSH protocol version 2
Doing Diffie-Hellman key exchange
Host key fingerprint is:
ssh-dss 1024 5d:99:13:16:8d:3b:e7:8f:1c:52:58:60:2c:47:64:45
Connected to 10.1.4.1
I have no problems to connect to debian machines which are running sshd (not sshd2).
So i would suggest its a problem with sshd2.
If you need further information just tell me.
Thanx in advance,
Grand Apeiron
Re: Can not connect and receive "Incoming packet was garbled on decryption" msg.
belamy2 wrote:
I've tried to use WinSCP2 ver. 2.2.3 to connect to remote host. My problem is I can not connect to remote server and recive message: "Incoming packet was garbled on decryption".
Please read PuTTY FAQ on "A.6.18 Since my SSH server was upgraded to OpenSSH 3.1p1/3.4p1, I can no longer connect with PuTTY" (<invalid hyperlink removed by admin>). According to this document, problem is on the server side. Workaround is to use SSH2 with Blowfish encryption. Please, let me know, if it helps.
