Only Partial File Being Synchronized to Server Before Connection is Aborted
I got successfully connected and can start the file sync but now running into connection abort issues. Not sure if this is a firewall issue or something else.
Note: My connection issue prior was due to SFTP password containing special characters and needed them specified as HEX values for the script to work. Thanks to this group for helping me there.
New verbose is below:
C:\Program Files (x86)\WinSCP>winscp.com /script=ecc-sync-inv-price.txt
batch           abort
confirm         off
Searching for host...
Connecting to host...
Authenticating...
Using username "Yesco".
Authenticated.
Starting the session...
Session started.
Active session: [1] Yesco@40.77.67.194
Comparing...
Local 'X:\ECCINV' => Remote '/live/ECCINV'
Synchronizing...
X:\...\ecc-inv-price.csv  |         343 KB | 5268.0 KB/s | binary | 100%
Network error: Software caused connection abort
Description: Partial file sent then aborts.
Re: Only Partial File Being Synchronized to Server Before Connection is Aborted
Can you upload the file in WinSCP GUI? Or in any other SFTP client? Can you post some log files?
twiggs462
US
I got this working, but how do I look at log files (or write to log files) when doing these batches?
