Unable to auto save file between sublime and winscp
tkkhan444
Kolkata, india
I use sublime text as text editor (Bild 4170), and as FTP client I use WinSCP (Build 11427 & v 5.18.5 RC).
When I press Ctrl+S during edit source code direct from server through WinSCP FTP it should save automatically in server, It works properly from first file the I open, from second file I get path error which you can see in screenshot 1, I attach also my WinSCP editor setting as screenshot in screenshot 2
I will be very thankful to you for resolving this issue.
Description: screenshot 2
Description: screenshot 1
Reply with quote E-mail
Re: Unable to auto save file between sublime and winscp
Can you post a screenshot of your "Sublime_text" WinSCP editor settings?
