Upload pdf to sftp server
mattejv
Dear friends!
Please help me to find my bug in uploading files to SFTP server. It is something with remote side directory listing. I can successfully upload to test server, production returns errors.
If I use remote dir $Rem_Dir = " /PDF/IN", I get :
Exception calling "Check" with "0" argument(s): "Cannot create remote file '/PDF/IN/NG#APERUTNINA#L31275648#C2#NA80#Z202152114240.pdf'.
Permission denied.
Error code: 3
Error message from server: file:///C:/PDF/IN/NG#APERUTNINA#L31275648#C2#NA80#Z202152114240.pdf"
At C:\pdf2ftp\skript\pdf2sftp_v1.ps1:93 char:13
+ $transferResult.Check()
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : SessionRemoteException
If I use remote dir $Rem_Dir = " home/PERUTNINA/PDF/IN", no files are copied...no errors?
I can manually upload with WinSCP GUI. The used script is in attached file.
Thank You very much!
With best regards!
Re: Upload pdf to sftp server
First, make sure you use the same full/absolute path in your code as you see in the GUI.
If this do0es not help, please attach a full session log file showing the problem (using the latest version of WinSCP) as well as a GUI session log file showing a successful upload.
mattejv
Hi Martin,
Thank You for Your time and help!
The log is in the attachment. Here i used remote path, under set home dir. I tryed this way to test sftp, with no problem. In next i will append with the same path as gui... there is no error, but i can not see the files in remote dir then...and so not sure where are they....
Thank You!
  • Nagel_log1.log (25.55 KB, Private file)
Why do you have two slashes here? Use just one.
Copying 1 files/directories to remote directory "home/PERUTNIA/PDF/IN//" - total size: 27.627
