Command to change file format to pipe delimited and copy to S3 bucket
bkandala@...
Hi All
I have the following script that gets the data from FTP server and copy it to my local drive.
option batch on
open ftp://username:password@FTPSITE/
cd /webpricingFTP/BC
option transfer binary
 get -preservetime *.csv C:\FTPShare\
What I am looking for is to change the file to a pipe delimited and copy to AWS S3 bucket, can someone please advice.
Re: Command to change file format to pipe delimited and copy to S3 bucket
WinSCP is not file format conversion tool. You have to use other tool for that.
Thanks, but can you please suggest how to move it to the S3 bucket bypassing the conversion part?
open s3://accesskey:securitykey@s3.amazonaws.com/bucket/
put C:\FTPShare\*
