Moving Remote File To Another Remote Folder
the1nonlyku
Hi all,
I've been trying to write a batch file that would move all .xlsx files to the archive folder, but it keeps failing. Could someone let me know what I'm doing wrong?
I've replaced my site info with test information since this has to do with my work. All of that information is correct since I got it from WinSCP.
I keep getting a error code 2. It says it cannot locate the file. I believe I am navigating to the file correctly. Any help would be appreciated.
@echo off
"C:\Users\kdixit\AppData\Local\Programs\WinSCP\WinSCP.com" ^
  /log="C:\writable\path\to\log\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://test:blahblahblah@ftp.test.csod.com/ -hostkey=""ssh key here"" -rawsettings ProxyPort=0" ^
    "cd /home/Reports/" ^
    "mv *.xlsx /home/Reports/Archive/" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Attempt Failed!!!
exit /b %WINSCP_RESULT%
Re: Moving Remote File To Another Remote Folder
Also can you move the files in WinSCP GUI? If you can, post GUI log file too.
the1nonlyku
When I attempt to log it gives me this error:
Error occurred during logging. It's been turned off.
Can't open log file 'C:\path\to\winscp.log'.
System Error. Code: 2.
The system cannot find the file specified
