"Calculate" in folder's properties doesn't display the total size on high DPI display
Kenshin9977
Though it should. The issue has to do with Windows, monitor and scale factor.
I have a 1080p screen with a scale factor of 100% and a 2160p monitor with a scale factor of 150%.
– If WinSCP is on the 2160p and then I open the properties window, the total size is displayed correctly, on both monitors.
– If WinSCP is on the 1080p and then I open the properties window, the total size isn't displayed, on both monitors.
Re: [BUG] "Calculate" in folder's properties doesn't display the total size
Thanks for your report. Which of the monitors is your primary one?
Kenshin9977
Sorry for the late response. My main monitor is the 2160p one.
I tested the version you sent me and it seems you solved the issue.
Here are screenshots with what I see with the current version and with the dev version you sent me.
