Tip when copying files to OpenVMS
KZ
Using version 5.18.4 RC (Build 11387) and copying (Ctrl+K) a file from Windows 10 to
an OpenVMS session, the destination offered by WinSCP may look like this:
Upload file FILE.TXT to remote directory:
/DKA300:[L.BLISS]/*.*
This fails. After a lot of experimenting, I found that the only formats that work are when I edit the above to:
/DKA300:/L/BLISS/*.*
/DKA300:/L/BLISS/
Trying /DKA300:[L.BLISS]*.* also works (second / removed), but does not copy the entire
name, just the extension, .TXT;1, for example. Playing with *, *.*.*, *.*;* and similar does not help.
I know that OpenVMS is not a high priority, so I'm happy to fix the above line manually,
but it would be nice for WinSCP to do the above automatically.
Re: Tip when copying files to OpenVMS
Please post a full session log file of an upload both with the default path and with your fix.
