Winscp failed for "Error listing directory" when using SCP to copy file from Linux environment
Kim Nguyen
WinSCP throws the error message when it tries to enumerate the folder that there is a file name with special (?) character in Linux environment.
Ex: POST_rest_closure_1?.out
Unexpected directory listing line '.out'.
Invalid rights description 'out'
Re: Winscp failed for "Error listing directory" when using SCP to copy file from Linux environment
