Change password of remote SFTP user using command line
sandhyamohang
I can find a change password option in the GUI, however I am looking for a away where I can change the password using command line. Any help much appreciated.
Thanks,
Sandhya
Re: Change password of remote SFTP user using command line
It's not possible from the command line. Most SSH servers does not even allow changing the password. Are you sure yours does? Does the password changing in GUI work?
