Network error: Software caused connection abort
fiziev
Dubna MO
WinSCP 5.18.3 under Windows Pro 10 20H2 gives permanently the message
and refuse to work.
Under older version of Windows 10 Pro everything is OK
Reply with quote E-mail
Re: Network error: Software caused connection abort
Can you post a WinSCP session log file from both machines?
Can you connect with any other SFTP client from the machine, where WinSCP fails? If you can, post its log file too.
  • fiziev@159.93.130.39.log (20.88 KB, Private file)
Description: works on old WIN 10 Prof
  • parc.log (6.58 KB, Private file)
Description: does not worl on WIN 10 Proff 20H2
I can send also coorresponding log files for WinSCP 5.17.10. The situation is the same.
And the same problem exists with NoMachine - last versions.
Thanks, but you didn't respond to this:
