How to enable Authentication logging
remkop
Hi, I use the basic example to upload file over SFTP.
I'm pretty sure I got all the correct settings like credentials and connections details. I used the same set for the command-line interface (and these are working).
When running the powershell-script I get this error; but I don't see any Authentication log or session log file...
Error: Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "XXXXX".
Access denied.
Authentication failed."
Re: Adding Logging
The Session.SessionLogPath should be enough. Do not keep the high logging level and debug log on. That consumes too much resources.
